Old 12-04-2020, 08:19 PM   #2
MrBen
Dj could also have a transmission starting to go out. Mine did that for a while before it finally failed. The left side where the switch is located could have a gear problem while the right has enough push to get the top to the point where you can close it. At least with mine it started working erratic jerking and such. It took mine about a year to finally go once the light quit working as it should
MrBen is offline   Reply With Quote
