Old 11-30-2020, 05:27 PM   #1
TNcargirl
About the door lock. When you insert the key does the cylinder rotate 360 degrees? If it does then the lock fix should take care of it. If it does not rotate 360 then it could be the rod that attaches to the door handle has come loose.
You do not need a low profile lift. The jack point is just in front of the rear wheel.
Door lock only rotates 180. when key is inserted it can turn a quarter turn in each direction (but not all the way around) In all the 10 plus years I've had the car I don't think I've ever had to use the physical key to open the door. (o that hindsight)
Rena Dudley
Sticking feathers up your butt does not make you a chicken :chicken:
TNcargirl is offline   Reply With Quote
