Old 11-30-2020, 03:34 PM   #2
986 Boxster
986 Boxster's Avatar
Jack the driver side rear up. You have the wheel lock key inaccessible so you will have to work around. Inside the back of the wheel well you should see a cover secured by torque screws. Remove the cover. You will need a good light. Inside the bumper youshould find a thin silver cable. Pull to release the rear hatch. This should get you inside.
I think OP knows that 911monty, at least that`s what I read on the first post, but with no lift to lift the car up, I can`t see how OP is going to lift the car up to get to the cable, and in case op needs to remove the wheel, the lock key for the bolts is in the car
986 Boxster is offline   Reply With Quote
