Old 11-30-2020, 03:07 PM   #1
911monty
911monty's Avatar
Originally Posted by TNcargirl View Post
Yes, car and key fob hadn't been used for a few weeks. (not intentionally... otherwise I would have set the car up on a trickle charger) I don't know why I'm so nervous about having a locksmith come out to open the car!!
Jack the driver side rear up. You have the wheel lock key inaccessible so you will have to work around. Inside the back of the wheel well you should see a cover secured by torque screws. Remove the cover. You will need a good light. Inside the bumper youshould find a thin silver cable. Pull to release the rear hatch. This should get you inside.
