Old 11-23-2020, 07:27 PM   #14
Wolf
Boxster 986
Wolf's Avatar
Wolf
After going back and rereading this thread I see you car is a 1998.
I believe your car has an "idle air control valve" as part of the throttle body.
Perhaps there is an issue with it that relates so the bog problem and the issue with the AC on when stopping.
I am not familiar with the setup so I can't be of much help.
I would do a search here on the forum and a general search on the "net".
I would scan you OBDII for codes or pending codes if the CEL has not set.
Then do some research and learn what you can about idle control valve issues.
I am not saying there is an issue with it just pointing out something to look at
Yes the code is thrown quite a bit actually, never really care since it goes away after a couple days anyways. I have looked up the valve on pelican parts, about $40 so not terrible, maybe it can be a winter project. [emoji3526] I’ll have to locate it first and give it a look, maybe just needs a cleaning.
Wolf is offline   Reply With Quote
