Thread: Boxster Prices
Old 11-22-2020, 08:44 AM   #11
darmahman
darmahman's Avatar
Ok - Here we go - Bought my 2001 Boxster S from the 4th owner from Boulder, CO in June/2020. 61,000 miles. My second Boxster(first was a 987) and 3rd Porsche (also owned a 1985 911). Paid $10,500. Came with a brand new already installed glass window top.
Changed the oil and filter immediately.
Took to Autowerks East in Lafayette, CO to do the following on June 24th of 2020:
PPI, replace tranny fluid, water pump, thermostat and drive belt and replace coolant. Brake and clutch flush, refinish headlights and replace bulbs, replace fuel filter, New spark plugs, air filter, cabin filter. Total cost - $3300
July 6th - AWE again - did the following:
LN IMS "Solution" installed. Mine had had the double row bearing in questionable condition.
New OEM clutch kit installed, flywheel bolts, pressure plate bolts, Clutch pivot pin, Clutch lever(it was shot), new OEM flywheel. Total - $5400.
I had already changed the oil and sent to Blackstone. Came back all normal there. Car is a happy camper. Hope to keep for a long time.
Present - 2001 Boxster S
Past - 1985 3.2 Carrera - 2005 Boxster
darmahman is offline   Reply With Quote
