Old 09-20-2020, 11:52 AM   #7
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by SGM Rick View Post
!997 Boxster with 101,600 miles. Window drops when I put top down but not when I open door. There is no play in the window if I push it or pull it. That's why I think it could be the microswitch.
there are three microswitchs, one for interior handle, one for the outer handle and the door latch assembly.
the drop of the windows when lowering the top is not related to the 1/2 inch drop when opening and closing the door.
if it is dropping at all, or not enough, all indications are the window regulator, otherwise, the likely culprit is the doorlatch MS, unless one or the other door handles work.
Most reliable fix is to replace the door latch assembly. Dealer (ouch), pelican (also ouch) ebay around 100 bucks or look for someone on the forum that rebuilds them for you.
NOTE: you need a triplesquare socket to remove and inspect the doorlatch.
