if it is dropping at all, or not enough, all indications are the window regulator. Don't bother with a cable tensioner, replace it. 100 dollar part and less than an hour of your time. I have had great experience with the URO, installed 5 or 6 of them over the years and all still working perfectly. Others have derided them
Quick tips:
set the screws on new regualtor to match old as this gets you really close if not perfect on adjustments AND spread the clamps that grab the window in advance. You dont remove the bolt, just loosen it and make sure the rubber glove is seperated. thank me later.
