Old 09-18-2020, 01:00 AM   #1
Robert986
Checking AOS
Ok, first we look at the AOS..
I did the oil-cap-test.
It really felt easy to open the oil cap, no powerful vacuum at all, but I realize this is totally subjective since I have no vacuum meter.
I then went on and popped the plenum & throttle body. I must say, there is some oil in there, but is it normal levels? As you see my finger get quite soaked when I scrape the inside of the plenum, I donīt see a lot of oil in the actual manifold. at least not a lake.. ;-)
So, does this mean that my AOS is not up to the job? Should I change it? I have been tracking with R-compounds, but not since last year, so I cannot imagine the oil beeing that old.
As you can see the throttle body was kind of dirty as well, cleaned this up.
Robert986 is offline   Reply With Quote
