Old 09-14-2020, 04:03 AM   #1
piper6909
piper6909's Avatar
Originally Posted by pilot4fn View Post
Thank you both for a good advice.
I'll try to avoid the re-boring these as well (some 30 years ago have done it and it was not so good result as I hoped for...).
Current plan is to paint the calipers, flush the brake fluid, swap the new seals and boots during this upcoming winter the latest.
You'll know better once you're in there if new calipers are needed. If no water has migrated into the cylinder and there's not rust or pitting and it cleans up well, new seals and boots will be all you need.
You may have a little rust and pitting along the outer edge (outside of where the seal rides) and you'll still be ok. Just clean it off real good so you won't damage the new seal when you insert it.
2010 Subaru Forester
piper6909 is online now   Reply With Quote
