Old 09-06-2020, 05:30 PM   #18
Qingdao
Qingdao's Avatar
After carefully heating up the bore (I didn`t want to fry the RMS behind the flywheel with the heat gun) and freezing the bearing it went in with not too much hassle:
I LOVE using heat when installing bearings and press fittings. I started using heat to the extreem to press in ball joints at work last year. I used to just use a ball joint press, but now I just cherry red the spindle and pop the joint in by hand. Then cool the crap out of the joint asap (yes I have melted the plastic bushings in the spherical joint once). It makes for a PERFECT press fit.
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
