Old 09-01-2020, 11:21 AM   #15
tonythetiger
Will there be cake?
tonythetiger's Avatar
That is the coolant flow control valve for the Tip oil cooler. Glad you got it sorted.
yep, quick question on the Burp Valve...when I pull vacuum, the tank fills with a little coolant and every 20-30 seconds, the tank bubbles and the vacuum drops about a pound.
Is this the burp valve leaking?
does the vent for this extend down to the bottom of the coolant tank, thus bubbles?
is this what I would see with a leaking burp valve?
