Old 08-21-2020, 05:21 PM   #3
Ciao
Ciao's Avatar
I do use the ramps on the rear axle...
As a first step to raise the rear end, then I use a 4x4 with the floor jack to raise it further up and to position the jack stands under the car jacking points..
This has worked out for me, and will do it until I can afford a lo-jack..
PS: I have never required to use the straps because I had always removed the wheels before removing the aluminum triangle (no weight on the suspension with the triangle removed..)
Great Tip!
5280 Cruising @High Altitude
Seal Gray & K&N Filter
