Old 08-11-2020, 05:13 PM   #1
piper6909
piper6909's Avatar
Originally Posted by 2ata View Post
Nut came off from the thread end with no issue. It's literally the smooth bolt through the wheel carrier where it is stuck. I previously confirmed that the entire bolt turns with the impact wrench.
See if one of there will fit over it:
https://www.harborfreight.com/3-4-quarter-inch-forged-ball-joint-separator-99849.html
If the bolt turns, all you should need some pressure to push it out while you hit it with the impact. The problem you're having now is that while the impact turns it, there's no pressure to pull it out. Actually the impact is probably applying force that keeps it in. You need pressure from the other side to push it out. Maybe this tool will help. It may even push it out without the impact.
2010 Subaru Forester
