Old 08-05-2020, 04:26 AM   #27
Seal1968
Seal1968
If you want an inexpensive and quick repair, and it's just the clear coming off you can sand the top layers with 400 wet, then re-clear. No need to break through the basecoat into the primer layer and have to re-spray the entire panel. When sanding the clear it will be a white residue...if you see colour on the sandpaper, you're into the basecoat.
To re-clear you can get 2K clear coat in a rattle can - it has the activator in it, and the UV protection needed. Cans of the 2K clear are @ $35 each.
There's a ton of DIY clearcoat repair videos on YT if you want to tackle this project.
If you feel this above your skill level, a body shop can blow in your hood and top lid easy. They will be able to match the paint codes. Even a Maaco shop could do this for you.
Seal1968 is offline   Reply With Quote
