Old 08-03-2020, 09:45 AM   #24
986Chick
Originally Posted by Qingdao View Post
Any body dings or dents that you couldn't live with?
You might be able to get away with a Maaco job if you aren't apposed to doing some 320 or 500 grit sanding before you send it in. Take the headlighs, tail lights and intake scoops off too.
That's really simple work you can do with a Philips head screwdriver and some patience.
What kind of sanding is required? Just rough it up, or do I need to remove clear coat, or what? And does it matter if I'm doing it by hand, using an orbital sander, or a circular one? I don't have the faintest idea what to do, but I'll do the work if I can learn and it will save me buku bucks.
986Chick is offline   Reply With Quote
