Old 10-23-2006, 12:13 PM   #6
jteixidor
Send a message via MSN to jteixidor
Not sure
Originally Posted by MNBoxster
Hi,
Is it Knocking or Popping? Two completely different things.
Knocking would indicate something mechanical, such as an engine internal or even a loose exhaust component.
Popping would seem to indicate a problem with the A/F Mixture causing unburnt fuel to ignite in the exhaust, this could be either a Rich or Lean condition caused by anything from a bad MAF to an Air or Vacuum leak. No Codes?...
Happy Motoring!... Jim'99
Not really sure, Sounds more like a pop in the exhaust. If you mean lights on the dash by codes, I dont have any lights coming on. Any ideas?
Joshua
Joshua
2001 Boxster
2.7 , 30K miles
jteixidor is offline   Reply With Quote
