Old 07-28-2020, 10:49 AM   #3
blue62
Originally Posted by Pattyg View Post
Yes the car does have misfire codes also. I thought a misfire May also cause the timing error code.
A misfire is not usually a cause it is most usually an affect.
a misfire can be caused by bad ignition timing, bad cam timing, cracked coil packs, fouled or cracked plugs, low octane fuel, and other things.
All the above listed are possible "causes" the misfire is the "affect".
