Old 07-22-2020, 11:30 PM   #10
jjjohnnyq
I did the delete about a month ago. The plastic stays on by virtue of the license plate holder. Plastic part goes on... plate holder on top... the screws... it's secured.
my delete plate is 3mm thick, so I put some doubkle sided tape on the back... to help it adhere. Didn't work for me because of the slight curve of the bumper cover. I'm going to give it a second look today.
So... just a couple license plate bracket screws... you'll be set.
Edit: The plate in the pic from your post is the exact one I installed on mine. Thanks, again, Mikesz.
Thanks for the info. Mine is going in next week and that back bumper has to come off for exhaust so I am going to get started. I am assuming those silver metal bumps that are hidden by the bumperettes just unscrew from the long metal " bumper " and leave the square area to be covered by the new back plate? Did you just cut out 3mm plastic to fit the opening? That might be a little above my pay grade , might have to have someone make it for me
jjjohnnyq is offline   Reply With Quote
