Start by testing your car battery and your alternator. Make sure it's outputting the correct voltage during idle and stressful loads. You said after 5 minutes you drain your battery. I assume that's because you kept cranking it. This will wear out your alternator and lower your battery life. If your battery is older than 5 years old you should monitor the outputs and anything pass 7 years, in most cases, should be replaced.
