Old 07-21-2020, 05:04 AM   #3
itsnotanova
Well to add to the list of things to check, I suggest looking for a vacuum leak. I believe if you remove the oil cap while the motor is running and the idle doesn't change, then you have a leak. Unfortunately there's tons of places where it can be leaking from. Most of the time it's the oil fill tube or crossover tube going from the intake to the AOS.
Woody
