Old 07-06-2020, 03:52 PM   #1
Phat Hippy
Phat Hippy's Avatar
Lewis, I would unplug the ignition switch under dash and check the amperage draw again. The switch is a constant cause of electrical problems. There are also a set of relays (fuses too?) in the trunk (not frunk). I hate electrical gremlins... Good luck I hope you find it. If it is the switch, replace it with the best quality OEM part you can find.
Phat Hippy is offline   Reply With Quote
