Old 06-29-2020, 07:58 PM   #10
TeamOxford
Damn Yankee
TeamOxford's Avatar
Heed what joliver3 and thstone advise. I would at least insist on an oil filter removal to check for debris. And a camshaft deviation analysis. These are two simple procedures that any accomplished shop can perform.
Originally Posted by beater986 View Post
Usually the money saved is exceeds the worst-case-scenario-repair.
This is utter nonsense. How would you like to skip the PPI and find metal filings in your oil filter at the first oil change? You may as well write the car off after that.
Or discover that you need new timing chain tensioners because the camshaft deviations are out of spec? Hope your credit card limit is high.
Not trying to be an alarmist, but knowledge is power. Know what you're getting into BEFORE you buy.
Just sayin'........
TO
