Old 06-24-2020, 09:03 PM   #10
piper6909
piper6909's Avatar
Originally Posted by thom4782 View Post
A warranty doesn't prevent actual failures. It simply says who will pay should a failure occur. Can anyone cite an example where a manufacturer warrants a part for longer that 5 years which, if the part fails, will destroy an engine that costs $15K to $20K to replace with a fresh unit.
NO warranty covers consequential damages, and at no time have I called for that. There are, however, plenty of lifetime warranties where they would replace the part, if it fails. Lifetime brake warranty, is just one example, but it won't cover your rotor if the pad fails and scores it. No one is asking for that.
All I'm saying is that if you claim your product is the "permanent solution" give it a permanent warranty. If not, you're just all talk and no substance.
Here's how I see it. Porsche offered either a 3 or 4 year warranty (I don't recall which time period it was). Now your at 100K+ miles on a car that is likely 12+ years old and its time to replace the clutch. You're way beyond any numbers that Porsche would stand behind. Now do you really want to bet that the original IMSB will last another 100K miles/ many years until your next clutch job. I wouldn't take that bet unless I planned to sell the car in a year or two.
And I'd agree.
If I had a manual transmission, I'd replace the IMSB when changing the clutch. But I would not spend 1/2 the cost of an engine on it. I'd get an OEM-style bearing for less than $50. If it lasted 100K+ miles, like your example, there's no reason why the new one shouldn't last 100K.
2010 Subaru Forester
