Old 06-13-2020, 01:38 PM   #11
hazardc
Compression is a bit high for that & power is not lacking!
The whole high compression + boost thing is overblown.. I've ran 13:1 compression with a large turbo. It's ringlands/rods/types of metal that matter at that point.
The caveat is at that point, i'd be very inclined to switch to e85, because e85 just refuses to knock.. I've pushed limits intentionally with it.. On most engines, you'll blow the side of the block out from cylinder pressure before you get e85 to knock (from advancing timing too much)
That said, meh. I'd rather have this in my car stock and reliable... I'm past the point in life where i want to wrench on my car more than I beat on it
hazardc is offline   Reply With Quote
