Old 06-09-2020, 04:54 PM   #23
lucoche
upper idler failure
Hello guys,
i have a 2001 Boxster S with 204 000 km on it, last saturday night i was coming home, and when i took the highway exit i revmatched downshift in 4th gear, then same for 3rd gear, and then my gf and I clearly heard a KLOK KLOK! right in our back.
Having lost the power steering, i initially thought about a flat tire, but quickly stopped to realize that my tires were all fine and smoke was coming out of the engine bay.
I quickly got back in the car, where now i could see the battery light on, so at this moment i figured out that my Main belt snapped for sure.
I replaced this belt myself at 170 000km in 2017 as a preventive maintenance, but i cheaped out the idlers as everything seemed to be fine with them.....WROOONG!
So as soon as I realized that the belt was gone, i was around 2km from my home so i decided to stare at the coolant temp gauge and try to go back home prior to overheat or just run out of battery, which i managed to do.
Today i opened the cover to discover the damage, remove any dust/chunk/strip/wire of what could initially be called a belt. I even passed the vaccuum in every corner that I could reach. The only damage that i could see was that the upper idler was completely destroyed ... here are a few images
Surprisingly, the bearing of this idler was still super smooth and quiet (i verified it prior to unscrew its bolt from the engine).
So, for all you guys who are thinking about just replacing the bearings inside it, think twice. The steel part of the pulley is actually pretty weak for a Porsche part. One one of my above pictures, look inside how corroded it is, my lower roller also shows the same rust flowers in the interior corner.
My conclusion on my issue is the following:
-The idler roller itself started to break due to fatigue and rust, which ejected the strap off and got worse as the strap was probably pulling hard from other elements in rotation...
My solution:
I ordered directly at Porsche Dealer a new belt, new upper and lower idlers, and the roller of the tensioner, for a 577$ CAD tax in. I will be replacing all the parts in 1-2 days, I will keep you guys updates if there is another problem with my car or not.
Sorry for the long story, thanks for reading!
lucoche is offline   Reply With Quote
