Thread: side vents?
Old 06-04-2020, 10:32 AM   #1
Tailwind
Tailwind's Avatar
The lower tab is likely snapped off. I had to replace both sides.
https://www.pelicanparts.com/More_Info/98650474700.htm?pn=986-504-747-00-OEM
But remove the screw at the top of the grille and check in case it was removed previously and not refitted properly. The tabs must be inserted in the grille channels.
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
Tailwind is offline   Reply With Quote
