Old 06-04-2020, 08:34 AM   #1
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
Your generic OBD reader just scratches the surface of the car's memory. And it can't always interpret the Porsche codes correctly. If you are a serious DIY and plan to keep this car long term, then invest in a Durametric cable.
Contact the shop and see if they will give you a list of the code numbers and report back.
I had a similar problem to yours (recurring codes). My generic reader couldn't see a fault in the trans module. I was able to reset it with Durametric and was then able to set the car for the CA smog test.
