Old 05-29-2020, 09:30 AM   #1
Htci
Part Numbers and Removal Process
Thanks Guys,
I'm looking at the following diagram for the o-ring part numbers and see more than two sets (total of four o-rings and that's likely due to the intermediate plate)... Also, after reading other posts related to oil cooler replacement I recall that some suggest an oil change. If I drain the coolant, bleed the coolant from cooler by removing breather tube, all of the coolant should leave the system so shouldn't I expect virtually no cross-contamination?
Please advise and thanks so much!
2004 Boxster S 79K Miles
Htci is offline   Reply With Quote
