Old 05-27-2020, 06:06 PM   #2
aparke4
Originally Posted by jsceash View Post
Also added the 997 oil cooler. The wires go to a switch/Gnd the engine bay fan and relay for the cooler fans, and a pressure sender on oil sump and an additional sender on right head. the floor was cut out under the cooler blows down the right side of the transmission. the 2 air checks in the trunk rear corners were removed so air can come into them while fan runs as well as 8 hole in the front wall. You can see one at thw front end of the oil sump.
Is the 997 oil cooler larger than the 3.2 S?
aparke4 is offline   Reply With Quote
