Old 05-19-2020, 01:59 PM   #1
Subman
Subman's Avatar
FWIW, on my car the PO had replaced the water pump after the impeller failed. Last year we pulled the oil cooler that sits atop the engine to replace the o-rings, which were leaking oil. While it was off we looked in the water side of the cooler & found a bunch of plastic shards from the impeller. Makes sense since it's one of the most restrictive places the coolant must flow through.
2004 Boxster S - 50th Anniversary of the 550 Spyder
2000 Carrera Cabriolet
2016 BMW R1200R
1971 BMW R75/5
Subman is offline   Reply With Quote
