Old 05-15-2020, 07:19 AM   #13
Zzorro
Zzorro's Avatar
You shouldn't have to worry about rust as Porsche does a good job with protecting them. Unless someone left a rock chip deteriorate, there shouldn't be rust situations. However, what you will need to take extra care of are the drain holes. If they get clogged and you leave it out in a rainy environment, your floors will flood or get wet. That's fatal as Porsche placed the CPU under the driver's seat - a perfect place for water to accumulate and fry it.
This is important. I related to this, I can also add, that if your roof is having any issues, make sure you look into it. If the end cap on the arm that moves your roof breaks you will end up tearing the "foam pan" that makes sure water stays out of the car. And you get the same issue. Ask me how I know! Some POs (Previous Owners)! But it's all fixable!
98 Boxster - Ocean Blue metallic. Bringing it back to life and having fun doing it!
20 Harley Streetbob -
Zzorro is offline   Reply With Quote
