Old 05-07-2020, 11:18 AM   #1
hotdawwgman
Originally Posted by Paul View Post
One solution is to install a 996 cluster and oil sender. Does your climate control work?
Just drove the car. The Climate Control is not working. I have no A/C in the car.
One thought was to flash the current cluster to a 996. Then reflash it to a 986. Hypothetically it should work, as sometimes you need to do this to calibrate your analog Speedometer on the 996 Instrument Cluster. Thoughts?
hotdawwgman is offline   Reply With Quote
