Old 05-06-2020, 11:08 AM   #1
steved0x
steved0x's Avatar
Originally Posted by redbox986 View Post
Thank you, upon further investigation it looks like I will be able to get the alignment close to OEM with just the adjustable toe arms - is that correct? I'm looking for no more than -2 degrees camber in the rear with street spec toe (about 0-0.10, I think).
That sounds like a good range, on my Boxster when I was lowered on PSS9 I think I was about -2.2 in the back with approx .08 deg toe in per side for a total of .16 degree toe in and before that when I was on M030 I (it has been a while) I think I ran that same toe but around -1.9 -2.0 camber.
Tire wear was good, considering I mostly did track work, but the highway driving to/from didn't cause a lot of inner tire edge wear.
