Thread: Tyre pressures
Old 04-14-2020, 08:40 AM   #2
phill
28psi Front
34psi Rear
While I KNOW what are the fronts... the rears you may want to double-check... for I run 16 all around, and you've an odd setup.
thanks for your reply. Yes I can confirm the rears are 18" and it runs and grips so well. I thought it odd but he ho if it works don't fix it. Just a concern about the pressures I should be running.
phill is offline   Reply With Quote
