Old 04-13-2020, 03:34 AM   #1
itsnotanova
Originally Posted by bcrdukes View Post
Thanks, itsnotanova.
Besides the leak, any symptoms I should suspect or look out for if it is the power steering fluid leaking like sounds, smells, or driving dynamis? I have noticed there is some kind of smell coming from the back of the car since last year, definitely some kind of chemical being burned off. It's not strong, but faint, and enough to notice.
As Rick said, check your ps fluid level. If it's low then more than likely you've found yuor problem. If it is your problem then you need to take care of it asap and don't run the pump dry. Replacing the pump is maybe the biggest PIA to perform on these cars. I think I'd rather pull a motor than replace a pump. You really need to get the car on some jack stands and look for yourself. Find the wet spot and follow it to it's source. No way you'll get a realistic answer by giving us a picture of two puddles on the pavement.
Woody
