Old 04-05-2020, 09:06 AM   #1
Frodo
Originally Posted by 1PorscheBoxster986 View Post
If you're trying to pull off the connector under the red arrow then you're doing it wrong.
Btw, I'm not sure I agree with the statement here. That is the very connection I was having trouble with. The new filter comes with the one line connected to it (the s-shaped line I referred to above). But the end of the filter you're talking about is the other end, the end where the ground wire (red arrow) attaches. If you look at the pic above (specifically the inset pic, at the lower right), it's the end of the filter that just has the short metal tube to which the fuel line attaches. So one has to remove that to insert the new filter.
Mine actually looked slightly different: it didn't have the 90° angle to it like the one in the pic. It's just straight.
Thanks for chiming in.
