Old 04-04-2020, 11:26 AM   #10
BYprodriver
BYprodriver's Avatar
Roughly how much would a standard rebuild be? Just stock parts, nothing built up?
You will need at least 2 good rods & most likely a whole set of rod bearings & ARP rod bolts. A gasket set is about $300, ARP rod bolts $160, bearings $125., Rods ?? You are looking around $1,000 minimum since you want to do whatever you can while you are in there. Plus labor!!
