Old 04-03-2020, 02:28 PM   #21
BYprodriver
BYprodriver's Avatar
Thank you, I think you may be right. I had a hunch it was the copper alloy from the bearings. But I wasn't sure if these bearings were made of a copper alloy or not. When I can get a replacement motor for less than $4k, it's probably not worth doing anything about it now, right?
Like I said earlier, I'm probably going to drive it for another one or two k miles and check it again.
If you pull it now before the rods & then Crankshaft are junk it will be some what economical to rebuild. Or you can go the route of replacing the engine every few years & never having one that's 100%.
