Old 10-17-2006, 07:17 PM   #1
MNBoxster
Originally Posted by insite
cars are drag-limited at a given power output. terminal velocity is reached when the power required to overcome drag for a given vehicle equals the maximum power output of the motor. for a vehicle of a given frontal area and cd, increasing the power output will increase the top speed capability.
agreed. pecivil's point, however, is still valid for track scenarios. a higher HP car will see higher average speeds around a track (given equal chassis). accordingly, the kinetic energy the brakes will have to shed increases. this will increase heat. as a brake system essentially changes kinetic energy to thermal energy, the job of a brake rotor is to get rid of that heat, hence the larger system. on the road, this makes almost no difference. on the track, it makes a LOT of difference.
Hi,
No disagreement here...
Happy Motoring!... Jim'99
