Old 03-29-2020, 07:42 AM   #4
imhighlander
Originally Posted by Anker View Post
You are nuts to use 19s for snow tires. The first time you hit a pot home your teeth are going to rattle out of your jaw. For snow tires you want to go narrow and small diameter on the rims. Narrow because it increases the down force in the patch and small diameter because it increases the width of the sidewall and helps absorb potholes.
I run 19s already and don't mind the ride at all. I did a full suspension refresh last summer (truly EVERYTHING with Porsche M030 ROW parts) and the ride is just fine. Current tires are Continental Extreme Contact DWS.
I have another set of 19" claws and after a bit of research have pretty much settled on Michelin Pilot Alpin tires next autumn.
imhighlander is offline   Reply With Quote
