Old 03-25-2020, 07:56 AM   #7
paulofto
2003 S, Arctic Silver, M6
paulofto's Avatar
Originally Posted by sfiorellino View Post
The 5mm socket isn't the problem. The bar that you turn inside the headlight assembly is stripped. Therefore I may need to replace the plastic headlight mounting plate that the headlight slides into. The headlight clamp is attached to the mounting plate which is what is stripped.
It isn't necessary to replace the whole plate. The 'clamping bow' is available as a separate item.
This is from the PET
996 631 243 00 clamping bow
