Old 03-15-2020, 07:28 AM   #1
BobRickel
BobRickel's Avatar
This worked for me when I bought mine and installed it. Inside the hardtop on each side, just above the spin lock levers there are two plastic covers that pop out to reveal three hex head bolts. To adjust the hardtop, secure the A-pillar clamp, then loosen the hex bolts on each side of the top. Have an assistant push forward and down as hard as possible on the hardtop, and tighten the bolts on each side. You may want to lock/unlock the Spin lock levers while doing this. Repeat as necessary. Make sure the Spin lock assemblies are well lubricated. Glad you are doing better, keep an eye on that blood pressure.
BobRickel is offline   Reply With Quote
