Old 03-13-2020, 06:34 AM   #1
Starter986
1998 Boxster Silver/Red
Hey Fred. It sure sounds like the ignition switch. Luckily, it's a cheap part and if you're nimble enough (to get under the dash) it's an easy DIY. There are plenty of posts in here on how to do it.
The other good news is that the switch is only the electrical part, not the tumblers.
So you can continue to use your key.
P.S. There's an original version and an updated version. Make sure you get the right one. Search this forum. You'll find a lot of good info.
Hey, Pipe!
What's the diff between the original and updated versions? Thanks!
1998 Porsche Boxster
