Old 02-26-2020, 08:09 AM   #7
Anker
You only need one fuse tap. One relay controls both fog lights.
I used a female spade connector, opened it up, widened the slot so the relay leg would fit through it and cut the excess off the sides. Slid the fuse leg though the slot and put the relay back in. Took all of 5 minutes to complete.
Yes, you do need to put the fuse tap in the correct way, but that's easy to test. Pull the fuse and if the fog lights go out you have done it correctly.
1941 Dodge Luxury Liner Coupe
