Old 02-26-2020, 07:01 AM   #6
9864ever
9864ever's Avatar
Do the DRL hack and put LED bulbs in. I have hd that for years in my Boxster, works great and no problems
Just ordered some LED's for the fog lights.
Just wondering if you used the same method using these parts that another member posted?
(10) inches of 16 gauge insulated wire
(2) Fuse taps, Radio Shack P/N 270-1204
(2) Female Quick Disconnectors, Radio Shack P/N 64-3131
And also to clarify, to activate the fogs as DRL's you have to jump from fuse #7 to Relay #12? I'm an idiot with electrical so want to be 100% sure on everything.
I also found something that might be cleaner and wondering if this would be an alternative to the fuse taps and quick disconnects - at least on the fuse box side.
I also read that it's important to distinguish which side of the fuse terminals is the hot side. What I understand is that the fuse tap has to link to the opposite side of the hot lead so that it will enable the fuse to blow if there's any issues.
9864ever is offline   Reply With Quote
