Old 02-25-2020, 06:20 PM   #2
9864ever
9864ever's Avatar
Originally Posted by Anker View Post
I have done the DR hack on both my Boxsters and really like the result. It turns the fog lights on any time the ignition is on. I also installed LED bulbs in the fogs. Search for DRL Hack and you shall find. It takes about 5 minutes to install with a fuse jumper to the relay.
Yes I read about the DRL hack, something about jumping fuses 6 and 9?
What you're mentioning is a bit different though with fuse jumper to relay so will have to do some more research.
So what you mentioned activates the foglights only then as DRL's and I would imagine the Canadian spec cars do the same thing right?
If that's the case that's perfect for me.
thanks!
9864ever is offline   Reply With Quote
