Old 02-21-2020, 02:16 PM   #4
piper6909
piper6909's Avatar
It's the 987 part # so my guess is Amazon doesn't know it's a match for 986. The part is very similar to the 986 part, bolt hole end to end it is the same length, the 987 part has a little more curve to it, maybe to give better clearance for the e-brake cable or maybe to give more clearance for bigger wheels?
Thanks. My concern was if it would change the alignment/geometry, but if the bolt holes are exactly the same, then it shouldn't.
Like I said, I changed mine last year, but it's good to know there's a cheaper option if I should need them again.
