Old 02-10-2020, 09:30 PM   #15
thstone
Originally Posted by lawren View Post
Still hoping to get an answer to the following questions:
1. Should i do a front or rear adjustable sway bar with stock shocks/struts? Or should i do both? Or should i do neither?
Do both. The staggered tire setup's will definitely tend towards understeer. The adj sways will help you balance the handling by dialing out some of that understeer.
2. Will 235 fit on front or is 225 the max with LCAs and stock struts?
235 should fit on the front with both the 7" and the 8.5" wheel.
