Old 02-05-2020, 09:08 AM   #10
Anker
Oh, I forgot.
Change your alignment.
Maximize the front camber with the stock camber slots. Set your front end toe-in to 0 degrees. Set a small amount of toe-in on the rears and set the camber to as much as you can with the selected toe-in (they interact). Use RE71-Rs on 17" rims. You will run 225 wide tires in front instead of the standard 205s. That's all Bridgestone supplies. That's what you want anyway because it increases front end grip.
1941 Dodge Luxury Liner Coupe
